Flywheel shim thickness?
    I am getting ready to do a 5 speed swap on my E30. I was gathering up all the parts and pieces and ended up with two different shims for the flywheel. One is 1/4" thick with one hole larger than the rest, the other one is about 1/8" thick and all the holes are the same diameter. Research on Realoem showed p/n 11-22-1-710-038 for the auto and p/n 11-22-1-262-827 for the manual. If someone has one lying around can you tell me if the manual transmission uses the 1/8" or 1/4" thick shim it would be great. If it makes a difference, and it did not look like it in Realoem, it is a single mass flywheel.
    Thanks,
    Jim
