using a 2.7 eta ecu with an eta harness on a m20b25...
  • Slick92GS-R
    • Apr 2005
    • 662
    even though i picked up my stock '173' 2.5 ecu today.. guy at the recycler threw me such a story .. it made some sense
    ..says if i use my same 2.7 harness and stock 2.7 but connected to the 2.5 motor i shouldn't have a problem .
    .. i know this, other than the obvious differences (head/cam/displacement/bore/cr/intake/exhaust/tb/flywheel) the only other major difference is the crank sensor position: tranny on the eta VS on the dampener on the 2.5..
    what had me going crazy is that he says don't truct a harness on a motor that came from a salvage yard and 1 pinched wire can cause u a great headache and i should go with a harness that is known good.
    --actually, what gave me ALL the doubt about his theory was when he sweared that the motors were only 2.3 or 2.5..-- jeez..
    -- so my question is... can this be made to work ?
    --Hayden--
    '87 325 coupe- Trak Rat
    '93 318is- 4cyl's of fury
    '92 Integra GS-R--yeah, its fast..
    www.G2IC.com
  • AndrewBird
    The Mad Scientist
    • 11898
    IIRC, you need the eta harness, but the i ecu. I think that's what we did on Josh's car when we did the swap.
    • rs4pro3
      • 5808
      WON'T WORK.....
      I ecu=3 row of pins
      Eta ecu=2 row of pins
      You can't plug a I ecu into an eta ecu
      Without an eta tranny, an eta ecu won't run the engine, with the I type sensors.
      85 325e 2.7 ITB'd stroker
      • PeaveyBassist
        • Sep 2004
        • 3511
        Also... the eta ecu will have a revlimiter at 4.5k instead of 6.5k on the i ecu
        Will
        RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
        Welcome e30 (brilliantrot '90 325is) 12/23/06
        DaveCN = Old Man
        My signature picture was taken by ME! Not by anyone else!
        If people keep quoting me in their sig, I'm going to burn this motherfucker down.
        • BavarianBimmer
          • 951
          Maybe an ECE spec 320i harness and ecu will work they exist in 2 row AND 3 row ecu's
          1989 E30 318iS_______________________________1989 E30 325iC M-Technic I
          1997 E36 328iT
          1990 E30 325iT 24v SOLD
          1989 E30 325i 2.7i M-Technic II SOLD
