So the eta LeMons car has taken a sudden turn. After getting the i cooling system installed, the dash and heater box removed and the suspension on, I went to fire it up and drive it out of the garage.
It cranks very strong (battery has been on a tender and reads 13.1V) but doesn't start. My dumbass realizes the ECU got unplugged during the dash removal so I plug it back in. I crank it again, for about 10 seconds. Still spinning strong but not starting. I wait 30 seconds, try cranking for 15 seconds. Nothing. Wait 60 seconds, try cranking for 20 seconds. Still nothing. I kept trying for a few minutes, giving the starter some time to cool down between tries.
At this point I realize that when I turn the key to position 2, I don't hear the fuel pumps priming. So I start checking all the fuses. Everything is good, nothing blown or missing. Only relay #K7 is clicking though when I turn the key to position 2.... shouldn't the starter relay and fuel pump relay both click? I swap a known good relay in for the fuel pump but no change. *sigh*
Anywho, after checking fuses and swapping relays to make sure all were functional, I put everything back where it was and try cranking again. This time I get absolutely NOTHING, not even a peep from the starter. Number K7 Relay is still clicking, but other than that I get SHIT ALL. Nothing from the fuel pumps, the ICV, the starter or the ECU. All fuses still good.
I know nothing about the electronics of the starting system in this car.... can anyone help to point me in a direction where I should start looking?
