turbo m20?
  • steezystef
    • Dec 2010
    • 113
    turbo m20?
    hey guys ive been doing some debating on what i want to do to my motor and so far it looks like i wanna go boost..
    anyways ive been trying to do the research on what turbo to use and all that but i havent found anything yet...i just want a small turbo,boost like 10 or in the 10 area, i want to build the kit myself..like piece it together because ive heard thats the cheapest way...also ive been looking at stroking it? i believe thats what its called, and curious to see if adding a eta bottom end will help my boost (by lowering the compression) oh btw i have a 325is so i just need the bottom end from what i saw..correct? idk im still doing research so if you know of any good ides that would be helpful thanks!
  • einstein57
    • Jun 2007
    • 10780
    Check out this thread. It will answer a lot of questions
    Also pick up corky bells maximum boost. Putting together your own kit can be cheap if you know exactly what you need and where to get it. A budget build can quickly grow to $3k. Also low compression, stroker, yada yada is not needed. Especially if all you want is 10 psi.
    www.gecoils.com
    • steezystef
      • Dec 2010
      • 113
      thanks bro
      • steezystef
        • Dec 2010
        • 113
        also couldnt i use any turbine?? i would think so right? as long as it bolts up to the manifold?
