After I warm up the car, I try to blip the gas a little and it goes down first then up. It sounds like its not getting fuel, like it wont rev like a regular car. I'll post vid if hard to understand. Car is running fine since I bought it.
M20 revs down then a little up when gassing it
I checked the air filter and look what I found, Ima clean the TB too
And heres the video of me blipping the gas and you can see the rpm goes down first then up.
How do you check if its bad? When I was cleaning the intake arm, I took the afm out and revved it with just the 90' degree intake boot/arm and it still does it. Second, I took the 90' degree boot to clean the TB, I revved the car with just the TB on(cleaned by the way) and it does same thing.Comment
I didn't check I just got a different AFM and the problem stopped;)How do you check if its bad? When I was cleaning the intake arm, I took the afm out and revved it with just the 90' degree intake boot/arm and it still does it. Second, I took the 90' degree boot to clean the TB, I revved the car with just the TB on(cleaned by the way) and it does same thing.
7speedshop.comComment
UPDATE: Got the new AFM in, runs a little bit better now, but rev still goes down first on idle when I blip the gas. I ran the car without the filter box. Anymore ideas? I'm not feeling the torqueness of M20. The car had history of overheating. PO had the head rebuilt, new exhaust valves, cleaned the head, new HG, Hoses.Comment
If I had a leak, would that change my idle? I'm not getting a crazy idle from cold to warm. Its stays in 800 til it warms up. It's just when I blip it, the engine chokes and is about to die on idle. but when I step on the gas halfway down. it revs to 1800rpm. Healthy engines revs about 2-3k just blipping the gas.Comment
mine does that, kinda stops for like half a second before it goes up. doesnt really go down in rpms though just kind of pauses before the upswing. ive never had an issue though. its only when its just started thoughOriginally posted by Lof8Seriously. Every black wheel, regardless of spoke design, looks the same from more than 3 feet away.Comment
