Simple question for those with experience building cylinder heads: If you use valves which have oversized stems do you need to use a different type of retainer?
For example, I know that many valve springs come with the valve retainers, but they do not mention valve stem size. Does it matter?
Obviously the guides will need to be sized accordingly or the correct guides need to be installed.
