Fuel Line Question
  • train80
    • 57
    Fuel Line Question
    I am Building my first e30, and i have just dropped my engine in and i don"t know where the 3 fuel lines distribute to. The three lines come up from the chassis on the drivers side right near the brake booster (indicated by the red circle). I know fuel has to go to the Pressure Regulator (yellow circle). Also there is a line that comes from the back of the intake manifold and the return lines (green circle). Trying to figure this out, so i can get my car running. Heres the picture.
    325e Parts For Sale/Trade
    Mein E46 2002 330ci
    / K&N Intake / Rear Strut Bar / Custom Nitrous System / 6000k HID Foglights / Orion V2 Angel Eyes / Carbon Fiber Emblems and Grills / Stealth Bulbs / LED License Plate Bulbs / Euro Rear Fog Lamps / Auto Meter Volt Meter / XM Satelite Radio / Alpine PLT-5 Subwoofer /
    Mein E30 1987 325e
    / Project Car / See my project fourm at: http://www.r3vlimited.com/board/showthread.php?t=185413
  • arty818
    • 9
    green circle is fuel line for ur cold start valve, should go into a T fitting coming from your main fuel line which should be atached to a fuel filter somewhere in the red circle.
      One of the two lines from under the car is the fuel supply and the other is the fuel return. To figure out which is the supply, connect a hose to each and point the hoses into a jug. Jumper the fuel pump relay and see which hose delivers fuel. The supply hose feeds the rail and cold start valve via a tee (as noted above). The return line goes to the fuel pressure regulator.
      If you are replacing the hose, the supply side hoses have to be hose rated for fuel injection service, but the return hose can be plain fuel hose.
      • train80
        • 57
        cool. Thanks.
        Mein E46 2002 330ci
        Mein E30 1987 325e
