Lets Start a Custom Pistons Specs thread for Different Stroker Combos
  • Overlord475
    • Dec 2010
    • 799
    Hey guys,
    Lets try to get a thread going that contains all the specs needed for custom forged pistons for various crank / rods combos for our M20 stroker projects.
    Lets state the following:
    Top design (Flat, Dome, Crown)
    Piston Bore Diameter
    Skirt Length
    Pin Height Position
    CR For Given Specs
    We all know the 2.7I combo
    Crank: ETA / 324td (81mm Stroke)
    Rods: ETA (130mm)
    Bore: 84mm (Stock)
    Pistons: 1988 SETA
    Now for the Crank / Rod Combos
    2.8L
    Rods: ETA (130mm)
    Bore: 86mm
    Crank: M52 (84mm Stroke)
    Rods: ETA (130mm)
    Bore: 84mm (Stock)
    Pistons: Can use stock 325i pistons
    Crank: M51D25 (82.8 Stroke)
    Rods: m20b20 (130mm)
    Pistons: Can use stock 325i pistons (machine skirts down ~14mm)
    2.9L
    Rods: ETA (130mm)
    Bore: 86mm
    3.0L
    Crank: S50 (85.6mm Stroke)
    Rods: S50 (135mm)
    Bore: 86mm
    Crank: S52 (89.6mm Stroke)
    Rods: S50 (135mm)
    Bore: 84mm (Stock)
    3.15L
    Rods: S50 (135mm)
    Bore: 86mm
    This way we don't each have to call MM and get stuck on the phone for 3 hours at a time, ha ;)
    This should be a great help when ordering custom pistons
    **** Let me know if I got something wrong or more info needs to be added / requested
    Thanks guys!
    --->>>1988 SETA 2.7i Build Thread (Turbo Prep)<<<---
  • MonkeyMadness
    • 3251
    Originally posted by Overlord475
    3.0L
    Rods: S50 (135mm)
    Bore: 86mm
    Rods: S50 (135mm)
    Bore: 84mm (Stoke)
    Oh so Sexy.... CR?
    this is all on M20B25 block and head?
    3.15L
    Rods: S50 (135mm)
    Bore: 86mm
    Interested in more info on these PLease....
    Are these N/A motors...?
    Makes me Wish I was into N/A and not Boost...:-(
    • Larsinnj
      • Jan 2009
      • 134
      For 2,8
      Crank: M51D25. Forged aswell. Don't know if it is forged on petrol M50.
      Rods: m20b20 130mm
      Pistons: Stock late model m20b25 with cat. Need to machine of the skirts.
      I'm running this setup. I took off 14mm from the underside of the pistons.
      Runs well. :)
      • tinkerputzer
        • Jun 2008
        • 508
        Page 4 of the MM PDF gives you a lot of good info for the different combination's available.
        • Overlord475
          • Dec 2010
          • 799
          Originally posted by Larsinnj
          For 2,8
          Rods: m20b20 130mm
          Runs well. :)
          Nice! What is the stroke of that crank; 84mm?
          • Overlord475
            • Dec 2010
            • 799
            Originally posted by MonkeyMadness
            Oh so Sexy.... CR?
            Yes, all of these NA stroker set ups are on the stock b25/b27 M20 blocks.
            Everything above the 2.8L M52 crank set up requires custom pistons however in order to move the pin position high enough that there is no piston/valve clearance issues.
            • XvillainousX
              • 176
              Crank: M51D25 (82.8mm stroke Stroke)
              • Overlord475
                • Dec 2010
                • 799
                Thanks. List updated....
                • Larsinnj
                  • Jan 2009
                  • 134
                  14mm sounds like a lot to machine of the pistons, but it works great. They are a little lighter aswell, but don't know if that matters.
                  Here is a pic of my pistons after they were machined. There is a little ring running around the inside of the skirts. I just took off the goods to that ring. :)
                  They got a real clean before going into the engine again. :)
                  • MonkeyMadness
                    • 3251
                    Question:
                    Ok so if I'm doing my math right and reading this here and at MM correctly..
                    The block M20B25 "I" and "E" that's stock at 84mm or 3.428" bore
                    can tack a hoging out or boring out to 86mm or 3.510" bore
                    If i'm not wrong that's a cut of .082 on the cylinder walls?
                    Now I must let you all know I have never built an M20 motor
                    so I'm not privy to this info...
                    thanks..
                    • MonkeyMadness
                      • 3251
                      Rods: ETA (130mm)
                      Bore: 84mm (Stock)
                      Need more info on this build setup..
                      I just happen to have a buddy sitting on an m52 crank
                      So i getting it tomorrow from him..
                      Any info would be helpfull
                      • Overlord475
                        • Dec 2010
                        • 799
                        Rods: ETA (130mm)
                        Bore: 84mm (Stock)
                        Using the M52 84mm crank you will need a crank spacer for the front of the crank so that oil doesn't poor out. One can be bought from IE for $60.
                        Here is a guy on e30tech selling a good set of ETA rods at a great price:
                        This crank and rod combo will set your pistons 0.5mm lower than stock.
                        If you're going to rebuild your motor I would do it right and not re-use used b25 pistons. I would at very least go with a set of MaxSil 84.5mm bore pistons. They're brand new and should give a nice ~9.8:1 CR when the block is planed down the needed 0.5mm.
                        Even better would be to go with a set of custom forged pistons provided by JE, Metric Mechanic, or IE. This will allow you to use longer rods (example: S50 135mm) for a better rod to stroke ratio and will be much lighter. The rods will also be lighter (~100g less).
                        This 135mm rod and 84mm crank combo will set your stock piston 4.5mm higher then stock so at this point custom pistons are a must.
                        With custom pistons you can also go with a larger bore and whatever CR you'd like.
                        Here is a great engine displacement calculator:
                        You could go with 86mm pistons which would give you ~2928.84cc (a true 2.9L)
                        FYI: this is the set up I'm using. M52 crank, JE pistons, and S50 rods. Though I am going with 85.5mm pistons to help with motor longevity
                        • Justin B
                          Sikky Nar Nar
                          • Mar 2005
                          • 4273
                          Buy the metric mechanic oil spacer, its more expensive but is actually a nice piece, not a chinese made piece of garbage. There was a thread around somewhere, maybe on the 'tech, and they tried to use that IE spacer, and gave up on it. Machining marks were terrible and it actually got stuck on the crank trying to remove it because of them. Steer clear.
                          • MonkeyMadness
                            • 3251
                            3.0L
                            Rods: S50 (135mm)
                            Bore: 84mm (Stock)
                            3.15L
                            Rods: S50 (135mm)
                            Bore: 86mm
                            Old a dead thread but I have a question hopfully some one can answer it for me....?
                            Can I sub the crank for the above builds with a M54B30 Crank
                            it has the same stroke 89.6mm??
                            I've also heard they are one in the same? Is this also true...?
                            thanks
                            • The Humjet
                              • Jun 2010
                              • 528
                              I'm pretty sure you can. Actually I've heard the s52b32 and m54b30 cranks have the same part numbers. Obviously you'll need to do some machining on the counterweights and piston skirts to fit this sort of crankshaft.
