Engine Gasket 'Kit' question
  • NigelStu
    • 827
    I have not been able to find a definitive answer on what all is actually included in the gasket kits that can be purchased through Pelican, BAV, etc.
    I am doing a e->i conversion (and adding on the I oil cooler) for my Chump Car project. I am obviously getting a new head gasket, and planned to buy the 'head gasket set' (~75-79 bucks on Pelican). And since I'm already doing some engine work, was planning on getting the 'Engine Gasket Set for Engine Block' as well - And hopefully eliminating all my leaks.
    My question is - are there any seals/plugs/gaskets that are NOT included in these 2 kits that would be a good idea to purchase separately? (I figured this would be easier to answer that 'what IS in the kit')
    Specific items I want clarification on:
    -Cyl head cam plugs (those 4 rubber block things)
    -Exhaust manifold gaskets
    -Oil cooler line O-rings/seals
    -Oil plug seal washer
    I'm placing an order this week and want to make sure I get ALL the parts required in one shot.
    TIA
    Ben
    Thelma-Louise, the '88is Chump Car - back to M20 power!
    2014 ChumpCar Season Schedule!
    April 5-6 Autobahn, IL - Sat: 1st! Sun: 3rd
    May23-25 Watkins Glen, NY: 4th, 5th, 4th
    October 4 PittRace Sprints: 2nd in C-class
    October 18-19 NCM, Bowling Green KY: 2nd, 1st!
    Nov 1-2 Watkins Glen - Chumpionship - 1st car to exit the race with significant body damage :(
    Find us on FB! Schaut Speed Motorsports
  • Farbin Kaiber
    Lil' Puppet
    • 29502
    Maybe on Cam Plugs, yes on exhaust manifold gaskets, maybe on oil cooler line o-rings, probably on drain plug seal.
    • tinkerputzer
      • Jun 2008
      • 508
      -Cyl head cam plugs (those 4 rubber block things) yes
      -Exhaust manifold gaskets yes
      -Oil cooler line O-rings/seals no
      -Oil plug seal washer possibly
      • NigelStu
        • 827
        I just want to confirm - by 'yes' you mean it IS included in the kit?
        Ben
        • kronus
          • Apr 2008
          • 13022
          Yup. Just did one on our Lemons car, the kit comes with cam seals, exhaust gaskets (they are shieldless, however). I did not see oil cooler stuff, but that is because we have an eta and got an eta gasket pack. No drain plug washer included.
          cars beep boop
