Valve tick
  • Philipangoo
    • 744
    Valve tick
    Not my video but my car sounds exactly like this. It wasn't always this loud, started happening maybe the last few times that I have driven the car.
    Mine is loud enough to hear in the car with the windows up. Does this sound mean I need another valve adjustment ? I adjusted the car a few months ago but I haven't driven it very often since then. It definitely didn't make this sound after I adjusted it. Could this be caused by worn valve adjusting eccentrics ?
  • Cabriolet
    • 9620
    you need to get your valves gapped to .10mm. that noise happens when the spacing is greater than .15mm.
    Much wow
    I hate 4 doors
    • Philipangoo
      • 744
      thanks for the quick response. Will try that this weekend.
      • matias88e30
        • Dec 2009
        • 1110
        Cabriolet: +1,
        are you running stock injectors?
        no more boosted m20, 91 318i...
          • 37829
          Some M20 engines will sound this way when they are running just fine with perfectly adjusted valves.
          The more wear on the parts in the cylinder head, the more noise. Not a big deal really if your valve clearance is correct.
          Classic BMW Specialists
          Grover Beach, CA
          www.BimmerHeads.com
            .1mm is .0039", which is way too tight. The correct cold valve adjustment is 0.010" or 0.254mm.
            The best way of adjusting the valves is to use a spring tool, available at BavAuto and other places. It completely removes the subjective factor when adjusting the valves. But understand that a worn head with worn valve guides will tick regardless of how perfectly the valves are adjusted.
            • Philipangoo
              • 744
              Ahh I see. Well before this, it was making some noise but not like this and not nearly as loud. I have put less then 100 miles on the car the past 3 months when I noticed the tick. Dunno if that means anything though.
              • Cabriolet
                • 9620
                thx, had forgotten the extra ".0"
                Much wow
                I hate 4 doors
