There is an option for the 93 octane chip that allows use with 17 or 19 lb injectors. If I have a choice of either, which one is ideal? Also, if I go with Bosch 19lbs, is the design II or design III preferable?
17lbs or 19lbs for Mark D 93 chip
if I recall correctly, the 93 is only 19lb. It should have the part number on the chip, you can check on his site.sigpic
Levent
%20levent@gutenparts.com
Ladies:
