shift light. please help me!!
  • LancE30
    • Jun 2010
    • 84
    please dont beat me up over this, but i have a proform shift light in my e30 m20b25 and i want to hook it up. has anyone done this/ what are my wiring connections needed to acheive this? thank you for the help.
  • Jaxx_
    • Dec 2009
    • 1880
    look at the manual?
    I'd guess you'd be tapping the low side of the ignition coil.
    • CabrioPunk
      • 1451
      Hook up to your NOS and LED underbody lights in parallel with a 5 farad cap.
      Por Que?
        As a guess you'll need switched power, a ground, and the tach signal from the DME. For the DME used with an M20b25 that is the wire that goes to pin 6 of the DME connector.
