fighting a problem with this car. 92 325i. Only starts when i spray carb cleaner in the intake, and stays on with throttle input. But runs very rough and CEL flashes. I pull code 1261 "fuel pump relay circuit" from the DME. While cranking the tach is jumpy goes up to 2k and all over the place.
Replaced fuel pump relay and CPS not any better. Checked pin 3 of dme to relay; looks good has continuity and .06 ohms. When I jump the the fuel pump directly to power it does not start either.
What kind of signal should I see come from the DME to the fuel pump relay?
Not sure really where to check next.
