Hello, my car is a 1986 325e Auto. The problem im having recently is my battery drains after about 10-12 hours of being turned off. It goes from 12.62v - 11.89v in 10 hours of sitting off. So i hook up a multimeter and i see i have a 173.3mA drain. I start pulling fuses and fuse 21 is drawing 33mA and fuse 27 is drawing 140mA both combined are the only drains on my battery, every other fuse combined = .1mA. I checked the fuse diagram and here is what i got.
21 = 7.5A - Interior Lights - radio memor - instrument panel lights
- glove box - rechargebale flashlight - clock - trunk light
- seat belt gong - ignition key warning gong - **OBC**
27 = 30A - Central locking system - door lock heating? - anti-theft -
- **OBC**
How do i tell which OBC this is? ABS, Idle Control, Motronic ECU? if it is one of these how do i test if its bad or needs to be replaced? ive ruled out every light and gong, because those i removed a long time ago. Strange that OBC is shared in 2 diferent fuses that are shared with random lights.. Need help Please!
-Artin
- **OBC**
-Artin
