I have a 88 325i..the car was working fine with no big problems.
I changed the plugs , changed all 4 discs and mostly maintance.
And i was trying to fix the afm because the po had the idle mixture screw to only half a turn. i set it to 3 turns out and it was whatever.
The next day my brother was adjusting the rear brakes and out of nowhere the car doesnt turn on anymore. I checked the main relay it was making the icv buzz and the motor cranks but doesnt turn on. I check fuse 11 and there is no power, I checked the fuel relay there is no power between 30 and 87. I checked the fuel pump connector and there was no voltage. What could it be? DME or something? Im stuck and this is a DD so I need help ASAP!
Thanks
Paul
Thanks
Paul
