Trying to diagnose an intermittent hard-start issue on my M20B25. The ICV is squeaky clean, oiled, and moves effortlessly from open to closed and back again. Does not seem to have any kind of spring return though - stays wherever I put it. What function test can I perform on the ICV to rule this part out as a cause for the hard start?
Car runs great once started. Per several other threads on hard starting, I have already:
If the ICV is good, I guess the fuel system tests are next. Any other ideas?
- smoke tested for vacuum leaks
- replaced injectors with rebuilt/flow tested
- new O2 sensor
