Do I need to pull the radiator to replace an M20 fan clutch? Or is it possible to work from under the car and finesse it out of there with the rad in place?
fan clutch install?
Just soak it in PB Blaster for a day, then use a 32mm wrench to turn the nut off. Don't forget it's left-hand thread.
I used a screwdriver stuck between the pully bolt heads to hold the pully.sigpic
Turbo Cabrio project: http://eurowerks.org/showthread.php?t=19677
the only important things to note are that the nut is reverse threading, and i'm pretty sure you can't fit an adjustable, although it's a big ol' nut. no need to remove radiator, just the shroud.1989 325is / 2.7, 274 cam, e30 M3 5-lug
1989 LN106 Hilux / 3.0TD SFA
1974 2002tii / stock
2002 IS300 / 5spd LSD
