Hey guys, so here is the run-down, I have (12/88) 89 325is that I bought recently and i cannot keep it from overheating. The thermostat operates properly, the water pump is working, and there are no visable leaks Anywhere.
When I drive the car it will get all the way past the mark after center, then shoot to the mark under center and gradually make it's way almost to red then cool down to center then gradually heat up again, and it will do that a few times before it doesn't cool off and I shut the car off (I've been stranded quite a bit)
I know the fan clutch, aux. Fan work. I've changed the temp sensor, flushed the system, and bought a new radiator and I'm still at square 1 during the little amount of time when the car is not running hot the heater blows hot air but otherwise it's ice cold. Frankly I've spent more on coolant and destilled water than I have on gas and I now could bleed my coolant system in my sleep. Before I got this car I was driving an 86 325e and I tell you what that sucker was a tank. HELP ME PLEASE
