Please help- Losing my F'ing mind, my patience, and my money.
  • lolcantturn
    • 4588
    i can't fucking stand this anymore, im going to get a craigslist ad ready because this car is absolutely killing me.
    Here's the last time the car was running:
    It sounds like it's on 5 cylinders. The morning after that it refused to start.
    I'm getting spark.
    I'm getting fuel.
    I replaced the distributor and rotor twice.
    I replaced the injectors twice.
    I replaced the spark plugs.
    I checked all sensors and they all read to spec
    Checked the main relays
    Rockers are good
    CPS is almost new
    Don't see how an AFM would fuck it up
    I replaced the DME for another one
    I cleaned out virtually every single connection on the car. Except C191...I can't get it apart
    On sunday it almost wanted to fire. I checked my new spark plugs and plugs 2,4,6 looked ignited while plugs 1,3,5 were still looking new.
    Please help....fucking losing it.
    Originally posted by TSI
    OEM+
  • MaxBell
    • 1391
    That's weird. My car did the SAME thing about 3 weeks ago. I pulled the distributor and there were some loose wires. All was well after that.
    I see you have replaced it twice, so that prolly has nothing to do with it. Just thought I'd share.
    REMEMBER: Be safe and have fun is Rule Number 1.
    The Epic Unbuild of Clint Eastwood
    • lolcantturn
      • 4588
      Yeah nope, not the distributor..
      The only thing I can complaint from the distributor is that my rotor is rubbing slightly against the distributor but im still getting good spark so that's ruled out
      OEM+
      • NC325iC
        • Mar 2004
        • 6565
        have you done a compression test?
        • Adrian_Visser
          • Jun 2006
          • 2823
          ^^This^^ Maybe the timing belt skipped a tooth.
          '89 Alpine S52 with goodies
          • lolcantturn
            • 4588
            Yes, and the test yielded low numbers in all cylinders, around 90-70PSI. My compression gauge is good as well. My HG is new, I know that my head has a small crack in one of the coolant passages, but i've driven like this for more than 4000 miles and it hasn't affected anything.
            Would it be possible that my belt skipped a tooth? I was running on the car extremely hard the week it broke down. Would skipping one tooth do any damage?
            How would I check my timing? I don't want to pull my crankshaft pully out..that would be QUITE tedious.
            Though I do apprecaite the help..ANYTHING at this moment would be helpful.
            OEM+
            • DaveSmed
              • Apr 2007
              • 1407
              Damn those numbers are shit. You held it at WOT while cranking, right? Try a wet test, put a little oil in each cylinder before you do the test, see if that helps any.
              Checking the timing is pretty easy, just make sure the marks still line up.
              -Dave
              2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
              Need some help figuring out the ETM?
              • lolcantturn
                • 4588
                Yep, WOT and the wet test didn't yield better results.
                How do I check the timing? What do I have to remove?
                OEM+
                • Adrian_Visser
                  • Jun 2006
                  • 2823
                  You'll have to remove your distributor cap to see the mark on the cam sprocket, just make sure you mark the plug wires and be careful not to strip the allen screws out holding the rotor.
                  • DaveSmed
                    • Apr 2007
                    • 1407
                    That's not a good sign. Was there any valvetrain related work done recently? Definite +1 on checking the timing too.
                    -Dave
                    • lolcantturn
                      • 4588
                      I know about the mark, if it alligns perfectly then my timing is good? All I gotta do is allign it?
                      No valvetrain work done recently..I mean I adjusted my valves like 500 miles ago.
                      I think it must be the timing, I don't see how all of my cylinders would have low compression numbers you know?
                      OEM+
                      • LJ851
                        • 7919
                        Your compression #s are shit. Do a leak down test and if that proves acceptable it is almost certainly cam timing. Yes , all you have to do is align the marks but you may want to double check it next time .
                        Lorin
                        The M30 is God's engine.
                        • lolcantturn
                          • 4588
                          How do I access the crankshaft marks?
                          OEM+
                          • Farbin Kaiber
                            Lil' Puppet
                            • 29502
                            I find it funny you've replaced all that stuff and you KNOW about the terrible compression numbers.
                            • lolcantturn
                              • 4588
                              I thought it would be the timing because my car had worked flawlessly..However the compression is one of the last things I found out about
                              OEM+
