Starting and headlights
  • green
    • Dec 2010
    • 128
    So anyone ever had this problem: my car cranks fine but doesn't start. It just so happens that the headlights don't work either (they work fine at other times when it is running). I looked at the wedophones wiring diagram and couldn't find a common ground with the headlights and any starting component (unless I missed something). Anyone have any ideas?
    • 37828
    Sounds like a possible ignition switch problem. Since the headlights only work when the ignition is in the run position this could be the issue.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
      I agree. The cause of this condition could be the ignition switch, a wiring fault, or an aftermarket alarm.
      • green
        • Dec 2010
        • 128
        Thanks guys! I'll look into it.
