Just finished (well, almost) a 2.7i swap (87 es received 87 is head, harness and 153 DME), and am getting loopy going through the forums and ETM trying to figure out my no start condition. Cranks, but no fuel pump operation and no spark.
RESOLUTION/FIXES at the bottom of 1st post - Thanks everyone for the help!
I have referenced JLevie's very good trouble shooting guide that seems to be in every single no start thread, and have narrowed it down to no start signal getting to the DME, but I'm not seeing an answer to my question on how to fix the issue.
Following Jim's guide, everything checks out OK (power to DME 18, main relay 30/86, grounds all good) except that I do not have power to DME pin 27 OR 37 with key on. I do have continuity between the main relay and those pins.
So - 2 questions:
I have tried multiple main relays, including a brand new one. But no help. CPS/DME/harness all came off of a running 2.5. Coil came off of the 2.7 that ran fine as well. Fusable link is good.
I have a feeling that I am missing something simple. Just cant see it. :?:
Thanks
For anyone looking for resolutions to similar problems...
THE FIXes
I had NO CRANK due to Black/Yellow start signal wire plugged into the wrong terminal. On a 4 terminal starter, the Black/Yellow start signal wire goes on the BOTTOM spade terminal (the one you can't see).
I had NO START due to:
1 - wrong main relay (relay needs to be 5-prong with two '87' terminals, not one '87' and one '87A). Order the correct one, it should have a white cap.
2 - C104 not plugged in. On 1987es --> 1987is swap, C104 contains the green wire which needs voltage for car to start. Plug it in to the normal plug, or if you want to pull the OBC (for a race car), then follow the steps in post #8. (note: I'm still confirming that with the OBC bypassed if the OBC relay box can be deleted as well. Confirmed: the relay box can be removed as well - and sold to fund your project!).
NO RUN:
AFM. Lesson learned, check part numbers for correct components. Just because someone selling a part says its for an 'is', check the part numbers... I had an 'es' AFM on the car. Put the old ugly looking "is" one on at it started and ran. Not great (hesitation with quick throttle opening, doesn't reach full RPM), but at least it runs.
Update - a bad AFM will allow idle, but not run right once you add part throttle (a good sign of an AFM problem is if car idles OK or can run at full throttle, but not at partial throttle). Swapped out AFMs with another 'is' AFM and the engine runs as it should now.
Summary:
-make sure everything is plugged in where its supposed to be.
-Check to make sure you have the correct relays in the correct spots
-Make sure you have the correct components for the system you are using
-One-by-one, check individual components with known good parts until you find the issue.
I hope this can help someone else.
So - 2 questions:
- Just to confirm, when checking power to pin 27/37, key on, main relay in but DME unplugged so you can actually prob the pin (if this is wrong, how do you check it?...)
- Assuming I did step 1 correct (unplugged DME to check), what are likely causes for no power to pin 27 and 37???? THIS is the info that I'm not finding in here.... I'm not sure where to look. ETM isn't helping me, but I might be looking in the wrong place?
Thanks
THE FIXes
NO RUN:
Summary:
