I need help please. Car won't start.
  • floppydonkey
    • 33
    I was at toco bell on a latenight food run and when I pulled up to the window I turned off my car to be polite since it's loud as crap and got my food and turned the key and I think it started to turn over then..nothing? You can turn the key nothing happenes. The auxilary workes fine i think cause the headlights and the gauges work fine. The headlights do not dim at all when you try to start it as if there is no draw? It wont push start. Battery isn't too low cause the first thing we did was jump it. If u have any ideas it would be greatly appreciated! thanks y'all :)
  • floppydonkey
    • 33
    Nevermind it was the ground strap the connects the oil pan to the body. I replaces the oil pan a few days ago and it was conected but not tight and apparently it vibrated loose. Anyways Keep that in mind guys lol.
      • 37829
      Isn't it amazing what a ground can do!
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • 7pilot
        • 475
        On older German cars I usually add a couple more ground wires from the block to the chassis.
        m
        • mr.vang
          • 4371
          ^that too and a loose battery cable will cause the car not to start. good thing you found the problem... anybody know the part number for that ground wire?
