Hi everyone, sorry again if this question seems rote, just getting used to M20s...
When it's cold, (Los Angeles cold, mind you, so like 50 degrees or so), the car starts right up, no issues. But for the first 30 seconds or so the idle bounces from 500 to 1000 RPM.
When I give the engine some gas, it stumbles a bit, but after a few seconds trying to rev it up, I can get it to rev smoothly. After I do this, the revs seem to even out and the idle is smoother.
At this point the engine seems to really bog every time I hit the throttle, either to the point of dying or almost dying. Revs drop for a moment then pop right up.
Because of this, I end up killing the car a lot, since getting out of my very sloped driveway requires me to be fast on the throttle. When I do kill it, it's really hard to start up again, and I need to wait for a couple minutes before I'm able to get it started again, and even then it takes a while to get going. Seems to be especially hard when I'm facing uphill.
I'm not throwing any CEL's, so can't speak to that. In previous cars I've had bouncing idle is related to bubbles in the coolant, but I haven't seen that mentioned in the searches I've done, so I'm a little stumped...would an intake leak be the source of all these issues?
