Car Died Month ago Now Wont Start
  • rblevins
    • Jan 2011
    • 282
    Ok so We had a used m20 swapped in a 88 vert about 2 months ago (New Everything From motor to Gas Tank, gas lines, fuel pump, the whole nine yards). Ran and drove great for about 2 weeks after we got it. One day when getting gas the car just wouldnt start. We pushed it out of the way and went back the next morning when daylight to work on it and it cranked right up. It did this same thing numerous times, until finally it just wouldnt start one day at the store.
    Took it to a trusted local mechanic, and was advised of the Motronic DME, bought a new one from someone here on the boards. Still no luck! the car will turn over all damn day just wont start like no fuel but with a brand new fuel pump and new lines this couldnt be the issue.
    Now im no mechanic but that IMO lol.Anybody had a similar issue? Or a fix to the problem?
  • etxxz
    • Feb 2006
    • 2085
    can you verify the pump working hmmmm do you hear it priming when you turn the key?? lift off the bottom of the rear seat (pops out) and hear again.
    If it cranks, most likely you have spark. You can also verify this by taking out a spark plug boot, and putting your finger to it while someone cranks it : P.
    If you have spark, you obviously have air the only thing missing is fuel to start... yeap, its that simple..
    No more e30s for me.
    88 black BMW OBDII 332is dedicated track [sold]
    88 BMW OBDII bronzit 332is [RIP 03/08]
    91 BMW 325i [sold]
    86 Corolla 'Ae86' HB 20v trd [sold]
    http://youtube.com/watch?v=pTj7Hn9v5Rs
    • gp.plus
      • 416
      Just because it cranks doesn't mean you have spark, I recently had the same problem, it was caused by a bad crank position sensor. A search will net you the proper ohm readings for a good cps, but mine passed all the tests and was still no good. Replaced it and she fired right up. In the least check to see that your cps wire has not come in to contact with the fan or any other moving parts on the front of the engine.
      Sent from my Droid using Tapatalk
      • e30rapidic
        • 2167
        check the main relay
        '87 325ic, powered by S50.
        • rblevins
          • Jan 2011
          • 282
          Well When I pull the plug out and try to start it I start smelling fuel like the car Is getting it but im not seeing a spark on the plug at all?
          Ok so I tracked down the cps wire running from the cps and the damn thing wasnt even plugged up lol....Plugged up and still no start.
          Where is this at sir?
          • rblevins
            • Jan 2011
            • 282
            Ok so I went to parts store and replaced the rotor button to try and get spark but still no good...
            • e30rapidic
              • 2167
              mine is located in the middle, orange I think. It 'should" be the lower of the three relays
              • rblevins
                • Jan 2011
                • 282
                Both have been replaced fuel pump and the main ;(
                • gp.plus
                  • 416
                  There is another plug near the cps plug this is attached to one of the plug wires (#6 I believe) it is the cylinder identifier sensor. Make sure that's plugged as well. Use a multi-meter to be sure the main relay is working, if the signal isn't getting to the relay to close, it wont power the dme.
                  • rblevins
                    • Jan 2011
                    • 282
                    Figured it out was main relay autozone had sold me the wrong one looks the same but not same circuit inside it.
                    • e30rapidic
                      • 2167
                      awesome!
