my 89 325i is making a really loud squealing noise and i cant tell what it is. the belts are still good and seem tight and when i rev the motor up it will go away but once the motor comes to idle or if im coming to a stop it will slightly squeal sounds kinda like a bad bearing or somthing and then when i go to accelerate it gets horribly loud until a certain rpm when it goes away completely. could it be my fan clutch?
LOUD squeeling noise from under the hood...
00 Z28 fully loaded modded beast
94 850i V12 6 speed
89 325i 5spd full suspension
88 325is 5spd 97k original miles all original
87 325 5spd 2.7 totalled still runs and drives tho
91 Z28 clean rolling chassis for sale
02 Z28 stripper RIP
00 Camaro V6 stripper/V8 conversion RIP
too many cars...Tags: None -
^^^ is this a typical problem? Would a water pump from an 87 325 2.7 work?00 Z28 fully loaded modded beast
94 850i V12 6 speed
02 Z28 stripper RIP
too many cars...Comment
id guess water pump. easy way to check fan clutch is to take it off and see if problem persists.
Also waterpump will have water seeping out of the weep hole if the bearings are toast. not allways tho so if it does end up being the pump replace it.RIP 84 323i coupe 5spd w/ 14psi
89' 318iComment
Yes. Water pumps go bad from time to time. Cross the P/N on realoem for the waterpump. I don't see why M20 pumps wouldn't cross...but just in case.
I would do the timing belt while in there, unless it was done very recently...in which case the waterpump should have been replaced....while in there.1974.5 Jensen Healey : 2003 330i/5Comment
once you change the waterpump even if you have a new belt there go ahead and put another new timing belt, once you re install a timing belt chances are that it might break sooner.
one more thing, is your 850i 6sp as fast as i'd imagine? being V12 and 6 sp?
HenryComment
no the water pump from the 87 will not work with the 89. The 89 has a metal cooling pipe a cross the front of the motor and the 87 does not. The pumps are not the sameComment
Remove all of the v-belts from the engine and see if the noise is still present. You won't hurt the engine by running it with no water pump for a minute or so with the engine cold. If the noise is gone, check each or the rotating parts for bad bearings. If the noise is still present with the belts off, the cause is the idle pulley on the timing belt tensioner.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
thanks for the help guys... im gonna try removing the fan then the belts and see if the noise is still there hopefully it is something simple.
^^ its quick up top but definately not really fast being such a heavy ass car but boy does she ride like a dream! and the subtle rumble of that motor sounds very nice00 Z28 fully loaded modded beast
94 850i V12 6 speed
02 Z28 stripper RIP
