Which main bearings do I use?
325i block, eta crank
Tags: None -
The proper bearings for your block. Also check crank size and get right size vs the crank.Originally posted by ZiMMieETA bearings.
Do not listen to zimmie.Tenured Automotive Service Professional - Avid BMW Enthusiast
https://mtechniqueabs.com/Comment
E bearing and I bearings are the same. There was a slight design update on the bearings after 3/88, but they are still interchangeable. As Jordan said, you just have to match the size to the crank if the crank has been reground; which is unlikely.Adam Fogg- '88 M3
Common sense- It's the new 'gifted'Comment
Cool, thanks fellasComment
