Valves or Timing belt First
  • kinvodA
    • Sep 2009
    • 278
    I'm doing my timing belt and valves this weekend. Which should I do first? Does it matter? There's no indication that my timing belt will break soon, I'm just trying to be pro-active and get some experience.
    "Wow. We're just blowing through nap time, aren't we?"
  • Cabriolet
    • 9620
    just don't do the valves if the timing belt if off. id do the belt first. then finish up the day with the valves. should take you a good 8 hours to do both.
    Much wow
    I hate 4 doors
    • StereoInstaller1
      GAS
      • 22679
      Pull the timing belt, pull the cam sprocket, do the cam seal (and housing o ring) then the water pump/belt/tensioner, then adjust the valves.
      Just like Cabby said.
      Closing SOON!
      Thanks for 10 years of fun!
        It doesn't matter in the slightest which you do first. But when you replace the belt, do as SeteroInstaller1 says (and replace the thermostat too).
        • StereoInstaller1
          GAS
          • 22679
          I always forget the damn thermostat!
          Closing SOON!
