What do these Numbers Mean?
  • nickflic3
    • Sep 2009
    • 3564
    Swapped in this i motor withought much of a background check as I was kind of desperate/it was cheap haha
    Anyway we figured out that the head was swapped out at some point due to the AMC stamp but we were stumped as to what year car this thing came out of. Would the 87 denote an 87 325i? Thanks
    And one more thing, what oil level sensor would an 87 i harness use? Round one was on the eta motor; square one came with the i motor...
    Many thanks!
    Cammed B25 Swap Daily Driver
    Updated 10/1
  • Van Westervelt
    • 9365
    I believe that harness (87) uses the smaller round one. But if the motor is from a late model 88+, you might have more issues with wiring thermostat etc.
      • 37834
      Yes, definitely an aftermarket head.
      You want the oil level sender on the right.
      Grover Beach, California
      BimmerHeads.com
      • nickflic3
        • Sep 2009
        • 3564
        Thanks, I'll swap those out then.
        ...if the motor is from a late model 88+, you might have more issues with wiring thermostat etc.
        Do I just need the right plugs then or is there more to it? I was hoping the numbers on the block would give a clue as to what year it was built...
        Comparison between eta and i thermostats:
        i thermostat came without plugs
        eta thermostat has 3
        (pix came out tiny for some reason; click to enlarge)
        Updated 10/1
        • nickflic3
          • Sep 2009
          • 3564
          Bump for some more info!
          Updated 10/1
            • 37834
            Van is wrong, all i engines use the same 2 sensors on the thermostat housing. Once is a double wide plug but with only one wire. Usually brown and for the temp gauge. The other is a 2 pin plug for the ECU coolant temp sender, usually blue. These are the 2 you need when running an i harness/ECU.
            BimmerHeads.com
