euro 323i will not stay running?
  • 4ce30
    • Feb 2006
    • 2762
    Car will only run for 5-10 seconds? It will do this a few times then it will not start at all. Let it sit for 10 minutes try again and it will start fine and die? Ive checked everything; vacuum, spark, fuel, air, ect. its all up to par. Im thinking its loosing fuel pressure somewhere, and my brother tells me there is 2 fuel pumps on this thing? I cant find much info on this car, any help would be greatly appreciated...
    Thanks!
  • DmcL
    • Apr 2009
    • 260
    when was the fuel filter changed last? had similar problems before that turned out to be the filter.. which knocked out the pump also because i didnt catch it in time.
    also maybe fuel pump relay or one/both of the pumps.
    Currently E30-less
    - EthosMotorsports.com
    • 4ce30
      • Feb 2006
      • 2762
      Fuel filter has yet to be changed, i hope i can catch it then!
      I will replace the relay and go from there hoping it didnt knock out both pumps...
      Thankyou Dmcl!
      • DmcL
        • Apr 2009
        • 260
        might not be filter/pump related but i had similar issues that turned out to be the filter needing changed.
        try the fuel filter first, probably the cheapest of the lot to try.
        Currently E30-less
        • 4ce30
          • Feb 2006
          • 2762
          Tomorrow i'll be able to work on the car and hopefully figure it out.. I'll let you know
          • 4ce30
            • Feb 2006
            • 2762
            Car still will not stay running.
            Replaced the fuel filter and fuel pump relay. Along with new afm, and we checked the fuel pumps and both are in working order..
            Im starting to think i may have some vacuum lines mixed up or possible another sensor out?
            • shay91
              • 82
              check your tps? that what i believe is causing my car to do the same thing. Best of luck I'll update you and let you know if thats what caused my mishap. My car is doing the same thing.
              WTB: 88 325i Convertible Top
              • 4ce30
                • Feb 2006
                • 2762
                No i have another whole throttle body setup i should just swap. I'll do that tomorrow and let you know aswell..
                The car ran great before doing the timing belt and waterpump!? Soo im beginning to think i have something hooked up wrong or forgot to put something back.. but damn ive checked over this thing a million times, just keep finding things to replace but it was running before..? haha the battle of owning a 30 year old car..
