173 ecu chip - check engine
  • Zorin
    • 67
    Hi,
    I recently purchased 173 ecu with ebay chip for my m20b25 (89 325ic) and once installed in my car it set the check engine right away - but no code is present. I disconnected the battery and will check tomorrow if the code is back. Is it possible that the code was set by low octane gas in the tank ? The chip is for 91. The car runs fine with the check engine on.
    gary muwaut
    89 325ic / 05 325i
  • Midnighttuning
    • Feb 2011
    • 30
    cheap ebay chip = Bad checksum
    renders your diagnostics useless till the problem is fixed... You need to buy a legit chip to solve the problem
    all the best!
    BarrieM/// BMW Tuner
    Email:midnight-tuning@rogers.com
    • Zorin
      • 67
      The chip is by DIGITECHNIK.
      I needed the ecu and chip was a "bonus".
      Is it possible that low octane gas is the cause ?
      gary muwaut
      89 325ic / 05 325i
      • Midnighttuning
        • Feb 2011
        • 30
        Never heard of them...
        I'm calling it a checksum error
        Low octane will not cause a CEL
        cheers
        • Zorin
          • 67
          cheers
          they are on ebay.
          i guess stock chip needs to go back.
          gary muwaut
          89 325ic / 05 325i
          • DmcL
            • Apr 2009
            • 260
            it will run fine just the light will be on..
            this seems like a bit of a hit or miss problem because most of the ones ive had anything to do with do not throw the engine light even with the checksum untouched while i have heard of 1 or 2 cases where the checksum not being corected has caused the engine light to come on. from what i gather it seems to happen moreso on USA/canadian models and not on european/UK models or atleast thats my experience so far.
            also +1 to fuel octane not causing a CEL. these ECU's arent that advanced..
            Currently E30-less
            - EthosMotorsports.com
            • Zorin
              • 67
              yeah, i am not a fan of cel lights on so i rather put the stock chip in it.
              gary muwaut
              89 325ic / 05 325i
              • george graves
                • 19997
                People always say that these ebay chips are all suppose to be copies of markD turner or dinan - but when they don't work right, you know they aren't.
                Here ya go OP: http://www.turnermotorsport.com/BMW-...1995-cars.aspx
                Originally posted by Matt-B
                • Zorin
                  • 67
                  i rather put the stock back into the ecu - i got the ebay chip as a bonus.
                  gary muwaut
                  89 325ic / 05 325i
                  • Zorin
                    • 67
                    reset didn't help - check engine came back on
                    replaced the chip and no check engine
                    gary muwaut
                    89 325ic / 05 325i
                    • george graves
                      • 19997
                      unplug the battery over night? - That might reset the ECu - don't know. What else did you change to the car at the time of doing the chip?
                      • Zorin
                        • 67
                        nothing was changed - battery was unplugged for 18hrs - flashing cel.
                        replaced the chip and no cel.
                        i guess previous owner assumed that cel was ok :-)
                        engine is stock m20b25 with 190kms.
                        the original 173 ecu had cracked connector so decided to buy another one as replacement and it came with the chip. i swapped the ebay chip with the oem one.
                        gary muwaut
                        89 325ic / 05 325i
                        • george graves
                          • 19997
                          So the cel was flashing before you installed chip/ecu?
                          • Zorin
                            • 67
                            no, before all was fine - no cel - once i installed ecu with the ebay it started flashing.
                            original ecu was fine except cosmetic damage to the connector.
                            gary muwaut
                            89 325ic / 05 325i
