325I VS 325E RPM Help....
  • capt100j
    • Dec 2010
    • 16
    Hi guys, finally just test drove the 1987 325IC that I bought at Christmas with a blown eng. I purchased a rust bucket 325IC 1989 with a good donor mtr, did the swap including the 87 intake to keep things simple. Hit the key, runs great. So I just booted it on the beach road. My Tachometer red lines at 4500 and only goes to 5K. @ 4500 it shut down and I had to shift. Is there a rev limiter in these things? I checked my data I do have a 325I.... I thought I could wind it higher......Runs great, no lights, love this thing! Thanks, John in NH where soon I will be driving with the top down.
    That swap should have included the engine complete with intake, exhaust, AFM, wiring harness, and DME. Is that what you did?
      • 37832
      Sounds like you just have the wrong tach in the car since both of your cars have the i engine.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
      • capt100j
        • Dec 2010
        • 16
        Yes I went from a 1988 325IC into an 87 325IC and used my intake manifold, exhaust, oil pan and a few other bits. Vehicle wiring harness stayed the same. I am curious why it won't tach up higher. Its obviously got the wrong tack, next winters project along with a new dash. It kicks out though at 4500 rpm very odd...
          The 5k tach would be one from a 325e. If you bought the car with a blown engine, it is possible that some prior owner may have swapped in the tach, engine, etc from an ETA. Check the DME and see what is in the car.
          • capt100j
            • Dec 2010
            • 16
            How do I check the DME? I know for a fact that they engine I put in is a 325I so would changing the DME for an E car to and I car do the trick? Did theyy ever make a 325E Cabrio?
