M20B27 injectors not firing.
Sparks fine so I assume the DME has good reference input (2 bellhousing sensors).
Cold start valve works great and car runs off that for a second.
No vacuum leaks (smoke tester).
Fuel pressure is good.
I have 12v at both terminals of each injector, and continuity to the proper DME injector pins.
This engine/DME/harness was all working fine before pulled from the car it came out of.
What could it be? I opened the DME, and I see no damage.
I've tried jumping the fuel relay and main relay, no difference. The fuel pump is running as it should with the relay anyway. I've tested all the DME plug ground pins, they're good. Tested the power inputs, they're good. I may have the wrong coolant temperature sensor installed, but that wouldn't cause no-start, right?
