request m20 headgasket replacement writeup?
  • fatsooo
    • 312
    agree with all the above, just finished doing my head rebuild.
    i turned the crank by hand (goes clockwise i believe look at the bentley) with the plugs out and left the manifolds on for easier removal/re-installation of the head
    def get the head (machine shop) and block (straight edge or other methods) checked for flatness and inspect your cylinder walls for cross hatching
    other things you can do "while you're in there" or at least what i did
    injectors
    clean the engine bay
    replace bad engine accessories (i did my PS pump)
    take a closer look at your engine harness (i ended up replacing mine)
    valve job (or port n polish if you're a baller)
    don't loose the head bolt washers, you'll hate yourself for having to go to a PnP just for those washers...
    • timninja
      • Feb 2011
      • 302
      Lol i had to buy my washers from my local bmw dealer i think it was $1.93 a washer
      • e30trooper
        • 11576
        This isnt to hard of a DYI , Also no need to remove the radiator.
        Discoonect all sensors , then coolant hoses, unbolt the TB take out air box. Unbolt exhaust manifold , remove valve cover. Next loosen timing belt , remove head. Your first time should take about half a day.
        • mrgraphics
          • 221
          An old school test you can do with the head and block: Buy a really large metal file, the kind you use for woodworking. Have it be fine cut. When they make these files, they are absolutely flat.
          Then you can use the file to check the flatness of the head by positioning it at different angles along the head and checking with a feeler gauge.
          May not be perfect, but will give you a good idea as to how warped (if at all) your head is.
          • 95BMWIC
            • Apr 2012
            • 353
            Came across this thread while search on how to diagnose a head gasket leak.. I have 3 E30's - and my second one is giving me a headache..
            I hought Id share my write up.. in case someone else needed it. (you have to sign in to see pics)
            My apologies that this is bf.com - I plan on posting more of these here going forward..
            • anpk05
              • Aug 2015
              • 1
              injectors
              Sorry for revival of an old thread.
              Which MACHINE shop did you use to resurface the head in Orange County, CA ?
              Thanks.
              • MrBurgundy
                R3V Degenerate
                • Mar 2012
                • 5616
                There is a shop called Head Exchange. Never had any issues with them
