no start, not getting any spark
  • seatown88
    • 331
    I'm trying to start my pro3 car for the first time. I have no spark. Things that I have checked and they passed are:
    1. I have continuity between DME pin 1 and coil(-)
    2. DME pin 1 and ground is open
    3. Resistance between DME 47/48 is 520 ohms (CPS)
    4. Resistance between DME 8/31 is less than 1 ohm
    5. I have continuity between DME 36 and main relay 85
    6. I have continuity between DME 3 and Fuel pumprelay 85
    With the battery connected and the key off I have power on DME 18, Main relay 86 and 30
    With the key on I have power on DME 27 and 18, the coil(+) and Fuel pump pin 30. There is no power on DME 2, 14, 19, 24
    So in short, I have power to the coil but no spark. I notice the fuel pump is not coming on with the ignition. I can short the relay and the fuel pump does turn on. I check the relay and it does click when power is applied to it.
    any help or suggestions would be great, thanks.
    With the checks you've done, I'd try a different DME at this point.
    • seatown88
      • 331
      I think it is the DME. Check engine light does not come on with ignition, can't run through the stomp test. If I ground pin 15 on the DME connector I can get the check engine light to come on.
      • seatown88
        • 331
        it was the DME. I put a new one in there and it fired up. thanks jlevie for all the diagnostic support you have posted, it helped tremendously.
