CEL is on.
Car runs retarded rich on idle
OBC reads 9.5mpg, and I've been driving very conservatively. I know the OBC isn't accurate at all, but in comparison I was doing 19mpg city according to OBC before.
Idle is a little rough.
Stumble on WOT
Timing is correct
When the engine is completely cold in the morning, I can turn it on and it will idle normally, at like 1500rpm since it's cold. It sounds great, then in about 2 minutes or so the RPM's drop completely and the car will idle at around 200rpm and wants to die. I have to keep the car revving until it gets warm, then it could hold idle, but rough.
Spark plug color is normal
No OBVIOUS vaccum leaks, I sprayed down every where where they would be a leak and nothing, except on the ICV port where I fixed that.
things i've tried diagnosing:
I adjusted the TPS so it "clicks," nothing.
I removed the dipstick while it was idling, and the idle stayed the same.
I removed the oil cap while idling and the idle stayed the same.
I rewired the C191 while doing my head, so I thought I might have screwed something up. I know the injectors are wired right since the wires are different from the temp sensors, but when I remove the blue sensor connection on the thermostat housing (coolant temp sender?) nothing happens. the car stays the same, the temp reads the same.
additionally, when I unplug the O2 sensor, the car still idles and feels the same and everything.
When I'm going on lets say, 3rd gear, at a relatively low cruising rpm, there will be SUPER SUPER slight moderate hesitations that would only be noticeable to me but no one else.
Help r3v!
Stumble on WOT
Timing is correct
Help r3v!
