Guys, I really need some help....
So far I've replaced: Fuel Pressure reg, ICV, O2 sensor, Plugs, Wires, Cleaned injectors, Checked for vacuum leaks and replaced purge valve hoses, Clicked the AFM 2 to rich side, tried emmisions still failed, Is now back to oem. The CEL light is on for..... what do ya know 1222 Lambda
EDIT: Also I forgot to mention, After resetting the DME and UNPLUGGING THE O2 SENSOR. While in open loop the CEL light will come on under CONSISTENT rpm's and then turn off if the throttle is closed or open more. When in closed loop the CEL light will come on solid and have a bit of a power cut. BUT the DME is not throwing a code for the O2 sensor being unplugged at all..... Without the O2 sensor, how would the DME know that it's running lean/rich (assuming lean because of high NOx)??
Crankcase vacuume is okay.
I haven't replaced AFM, nor have I done a smoke test.
Heres a video of the terrible throttle repsonse and bogging down.
Thanks!!
Tyler
Thanks!!
Tyler
