So I recently swapped the blown m20b25 in my 89'325iS with a replacement m20b25 (I am told it is from an 86 or 87) that sat outside on a pallet for years. That said, the engine still runs like absolute shit. I have a very rough idle and it smells like the engine is running rich. I have begun the diagnosing process with a friend of mine who is far more educated on e30's. He unplugged the AFM while the car was running and it sputtered and died. After a few seconds to reset, we plugged the AFM back in and started the car. This seemed to fix the rough idle and the engine ran smoothly but after about 5 - 10 seconds the engine started to bog, the rough idle returned and quickly returned to the same terrible running.
I never get full power out of this engine at any rpm. I should also add that the engine does not have any apparent misfiring or chattering at rpms higher than idle, and at cruising speeds everything sounds fine (barring the disgusting lack of power).
Is this phenomenon of "good idle moments after AFM reset" that turns to "bad idle after engine gets running" the result of a bad AFM or something else?
Thanks!
Thanks!
