1985 325e into 325eS Clutch Questions
  • dinanm3atl
    • Feb 2007
    • 7305
    Working on this swap and decided to do some more work.
    Engine is a 1985 325e(M20B27). This has a dual mass I believe(have not cracked it apart yet spent my time swapping engine harness). Now can I install a single mass from a 1987 325i? If I do which clutch do I need to order? One for a 325i? What year? Use all the same parts otherwise? Same starter?
    Going into an 86 325eS.
    Thanks!
    No you can't use the single-mass flywheel from a 325i. It won't have the timing sensor slugs that your engine requires. You can use the single mass flywheeh from an M20B27 (eta). I've got one if you want it.
    • dinanm3atl
      • Feb 2007
      • 7305
      Interesting. Then I use an ETA clutch I assume?
      How much plus shipping to Atlanta?
        I'll have to weigh it to find shipping cost. PM me and we will work out the details.
