I'm not getting any spark and I have changed out my spark plug wires with new bosch spark plug wires. I have plenty of fuel, not the starter nor the alternator and it has compression. Any ideas on what I should check?
Car turns over but doesn't start
Tags: None
No spark when cranking could be:
No timing data to the DME (bad CPS)
No power to the DME (bad Main relay or Fusible link)
No ground to the DME
No Start signal to the DME
Bad coil
Bad distributor (or a broken timing belt on an M20)
Bad DMEThe car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
Went with the first thing you mentioned and it was indeed a bad CPS and there was also a bad relay. Thanks jlevie!Comment
