I know somewhere there is a writeup on in "e" to "i" swap, but I lost the link. Anyone have it? I am trying to get an idea of what needs to be replaced to make this work.
M20B25 to replace '87 M20B27
You'll need the new wiring harness.
The flywheel - you can use the one off the B27 - but it'll be dual-mass. SInce you're in there, you might as well convert to single mass and put in a new clutch and everything.
I'm not sure if the reference sensors are in different spots, but your tranny should mate right up - if there's a hole in the tranny for a sensor, just plug it up. The sensor on the new 89 is on the front of the engine on the crankshaft balancer.- Sean HayesComment
I'm not sure if the reference sensors are in different spots, but your tranny should mate right up - if there's a hole in the tranny for a sensor, just plug it up. The sensor on the new 89 is on the front of the engine on the crankshaft balancer.Current Cars2014 M235i2009 R56 Cooper S1998 M31997 M3Comment
No, the auto doesn't have a flywheel, it's an auto... :ohsnap: (it has somethin else, but i'm having a brain fart, so I can't remember what's it called specifically)
lol
Get a single mass I flywheel off ebay, take it to a shop, have it lightened, and get a new OEM Sach's clutch kit. Wear the clutch in for like 500 miles. I did it for mine, and it grabs SOO well. hehe
If you're reference sensor is up front, then no worries for your 5spd tranny - it'll work perfect.
Robert's not kiddin about the dual-mass gayfer flywheel. It's LAME. 27 lbs of GAYNESS lol What you want is 12 lbs of GOODNESS!
Lightweight flywheels are HEAVAN! :)- Sean HayesComment
Originally posted by SeanNo, the auto doesn't have a flywheel, it's an auto... :ohsnap: (it has somethin else, but i'm having a brain fart, so I can't remember)
lol
I can get an I flywheel pretty cheap locally. Thanks for the advice.Current Cars2014 M235i2009 R56 Cooper S1998 M31997 M3Comment
its still called a flywheel. a flywhell is what the starter turns. the autos have a flywheel with a flexplate on it for the torque converter. the manuals have a flywheel with a wear surface for the clutch :idea:Comment
