Fan clutch
  • Jinaman
    • 147
    Fan clutch
    I cant for the life of me get that 32 mil loose, i read it spins reverse to loosen but the whole assembly moves no matter how i go about it.
    Any one know a good way to get this done or is my car just being mean. :(
  • KenC
    King of Kegstands
    • 14396
    Use the fan clutch removal wrench set.
    Originally posted by Gruelius
    • Jinaman
      • 147
      i tried finding one, is it motor specific or a universal kit
      • urbancynic
        • Dec 2008
        • 384
        I used a pair of large channel locks to hold the pulley in place while I gave the 32mm wrench a quick tap with a good sized hammer. It did the trick nicely.
        • Jinaman
          • 147
          would the pulley need replacing?
          • urbancynic
            • Dec 2008
            • 384
            Not in my case. I didn't grip it with the channel locks on the grooved part of the pulley. I used the smooth section of it just between the belt and the fan clutch.
            It can be rather difficult to get a good grip on the channel locks and still be able to get that wrench moving, so help may be required.
            • Cabriolet
              • 9620
              i bold a long thin metal bar with a hole in it to the bolts on the pulley. makes it come off really easy. the bar is 2'x1"x1/8" to the bolts shown below.
              i take 1 bolt off then with the same bolt bolt in the metal bar.
              Much wow
              I hate 4 doors
              • JrCamacho
                • Feb 2011
                • 618
                i used a visegrip and then used a prybar as a punch, hammered that sucker down, and it came loose.. i already had the radiator/shroud removed at that point.
                • slammin.e28
                  שמע ישראל
                  • 12054
                  We've got a kick ass fan clutch tool at work that you hook to an air chisel and just pull the trigger.
                  Works-every-time.
                  • Killacortes
                    • 1937
                    i jammed a screwdriver between the pulley bolts to keep it from moving
                    r3v does not fuck around. First you get banned, then they shoot you
                    • billybobjoseph
                      • 213
                      I used a chain wrench on the pulley and a 1 1/4 inch open end wrench
                      • Jinaman
                        • 147
                        Lol broke a cheap driver and my dizzy tryin that last night
                        Do you know the spacing on the holes, its kind of hard to get measurements on them right now
                        I got the fan clutch tool at oreilys but the closest size is 68 mill it seems to need a 67
                        • Killacortes
                          • 1937
                          you live in btown? as in burlington wa?
                          • Jinaman
                            • 147
                            Bothell, its just south of Lynnwood. A bit far from you, if you had time id cover gas and beverages
                            • Jinaman
                              • 147
                              Ive been spinning clockwise, i read to in a how to can anyone confirm this is how i turn it
