M20 E block, one bad piston
  • NbAmTwE
    • Jul 2010
    • 148
    So, I'm gathering parts for an e30 I bought to be a fun weekend trackrat/mess around car. I have an 86 325e and will be doing an I swap on this block. I pulled the head today knowing I might see one issue, the PO bondo the radiator a bunch and I found some of that residue in my coolant hoses and fluid. So, when I pulled the head off here is what I'm having to work on...
    and...
    I'm sure this last one is okay, all the other are fine; no damage to pistons and valves look okay to use but I won't be using that head.
    So help me out guys, I know I need to send my head off to a machine shop when I receive it to make sure it's not warped and what not. Should I go ahead and send the block as well to be cleaned up and will I need a new piston or is that fixable. It may be hard to tell from the pic, but this seems to be the result of some bondo running through the coolant passages and some leaking into this cylinder. Any advice is better than what I would know.
    UNDER CONSTRUCTION - 24v 325e (future DD), DD 525i
    stripped out e30 rally project - in progress
    M50NV -> M50TU E34 swap underway
  • Myster-E
    Performance
    • 552
    I dont know how bondo got into your radiator but its not gonna leak into the cylinder and cause that. that looks like water that rusted the cylinders and pistons. You might be able to salvage the pistons. pull it apart and inspect the cylinder walls to see if its even worth using that bottom end. Otherwise, I would just get another eta bottom end. they're cheap
    1988 E30 335i - 1987 E30 327i - 1987 E30 327iS Pickup - 1973 2002 Project
    Visit www.BimmerHeads.com for all of your 12 valve needs!
    • NbAmTwE
      • Jul 2010
      • 148
      that's what I was thinking when I saw that, I'm pretty sure I know where an eta bottom end is just laying around in my town.
      • MTechnikII
        • Jun 2007
        • 83
        aren't those pistons made of Aluminum alloy? they shouldn't rust, at least not like Iron.
        Henry
        • lolcantturn
          • 4588
          That is the strangest thing I've ever seen
          Originally posted by TSI
          OEM+
          • billybobjoseph
            • 213
            I'm going to have nightmares because of that pic
