Idle Issues
  • SoEm0
    • 449
    Idle Issues
    Ok, I just finished doing all sorts of maintenance. TB, WP, head done up (valves adjusted, new seals), HG, and pretty much all other maintenance things. Now I go to fire the car up and the idle instantly jumps to 2k rpm. Nothing I do can get the rpm's to drop. Any guess why it does this? I searched for hours and have not found anything that really resembles this issue. Your help would be much appreciated, I would like to get this bad boy ready for BF.
    CCW- when every second counts... The police are just minutes away!
  • slammin.e28
    שמע ישראל
    • 12054
    My guess is you missed hooking something up...I do that all the time.
    ...oorrr, did you use all new hoses? Like the CCV hose, intake boot, etc? If not, you coulda cracked one upon re-installation.
    • SoEm0
      • 449
      Yeah pretty much all new hoses except the radiator hoses
      • SilentJon
        • Feb 2011
        • 88
        it would barely run if one of the hoses or boots was cracked, not idle high
        • browntown
          • Jun 2004
          • 3524
          Drive it around and see if the computer learns maybe
          • slammin.e28
            שמע ישראל
            • 12054
            Maybe if it was a wide open, gaping hole. I'm not talking the Grand Canyon. The ICV hose that goes into the throttle body (on that metal "L") likes to come lose and leak air. The CCV can crack at the terminating ends and cause a high idle. It's a small leak, not a gaping hole. The engine is getting slightly more air, so it runs higher, whether it is metered or un-metered.
            • wildstoats
              • Sep 2007
              • 896
              By TB do you mean throttle body? If so what kind of maintenance was performed on it?
              • slammin.e28
                שמע ישראל
                • 12054
                Yes, throttle body. The little metal "L" likes to come lose. It's only pressed in there, and they can come out/loosen up and create a small vacuum leak.
                On the far left of the throttle body in this pic is one. There is another one (or two) on the other side for the vacuum booster.
                • SoEm0
                  • 449
                  No I meant timing belt. I got the idle down last night. I broke loose the idle adjustment screw and backed it off. Now she idles just fine, man I was stressing about this.
                  • hotballs
                    • 1155
                    Where is the idle adjustment screw? Didn't know an m20 had that...
                    • PNWDan
                      • Feb 2011
                      • 1326
                      there isnt an idle ajustment screw. Theres a stop screw for the butterfly. You just compensated for the bad idle with it. The ICV controls how much air is let through. Sounds like ICV or TPS issue to me. Sometimes cleaning the throttle body can screw up the TPS if cleaner runs down the shaft and into it etc..
                      1987 Alpinweiß 325is
                      Like the PNW E30 Local Crew Facebook page
                      • SoEm0
                        • 449
                        I adjusted that top screw to the specs i found in the bentley and its running great now
