well it all started when my 86 325 es started acting funny. i started it up one day and it idled like a badly tuned 350/ sounded like it was running on 3 cylinders.once it warmed up the power would smoothen out (not good, just better) and had lack of power and surges in speed while cruising. also had this "dirt" like stuff showing up on my coolant cap- found out that it was exhaust. did a comp test and found that all had 170 psi except for #5 it had less than 90. car has around 200k. ran good till now- i have had this car since nov. 2009
(yes my hood is purple, and yes the clear is fading- need to re-do it)
well on to pics: already took off the valance and started pulling off all the hoses
end of the day she looked like this
took off the cover
then came the head
woot! i was happy to get it off
i checked it out, valves uber clean. seemed fine
piston shots: right to left
was funny because #5 was the cleanest, but the face of the valves on #5 was the dirtyest
then took it over to my bros house for a better look. turns out that the PO had decided to clean the aluminum head with a steel wire brush! and some of the scoring was so deep around the cylinders that it caused blow by on #5 and it looks like any of them could had blown in their current condition. so my bro takes it to his work, welds up the spot, and cleans up the head. no worpage! yayy
while my head was off decided to raise my engine by putting in some spacers,just enough to put the pan higher than the sub support
then ordered all the gaskets and a few other lil things from autohasAZ. spent $168.88 haha its soo easy to just buy a bunch of tiny lil things that you might as well get
IT CAME TODAY!!!! (always wanted to say that and post pics) :-D
11 pounds of goodness...
well now its a rush to get her back together to make it for Bimmerfest. time to do work
-many thanks to Nickflic3 for my newer front bumper and many extra parts to help
took off the cover
then came the head
