87 325e Clutch options/question
  • blacksport325
    • 231
    It's time for me to change the clutch in my 87 325e, I believe it has a 8/86 production date but I will check in the AM to be sure. My question is I see clutches online with "springs" built into the clutch disc, and some that don't have these springs, how can you tell which one you should need or is this a single vs dual mass flywheel difference? From what i've read a 87 325e should have a dual mass flywheel. Thanks in advance.
  • new2e30s
    • Apr 2011
    • 5
    My understanding is the same as yours.
    Dual mass flywheel = no springs in the clutch disk
    Non dual mass flywheel = springs in the clutch disk
    • blacksport325
      • 231
      Good deal, thats what I figured...if I can get a definite answer I will be buying one this week
      • blacksport325
        • 231
        Anyone changed the clutch in an 87 eta and can let me know if it had the springs in the clutch plate?
        • new2e30s
          • Apr 2011
          • 5
          have you removed the old one yet? Does it have springs?
          If you are trying to order parts before you take everything apart, why not order 2 clutch disks, one with springs and one without then return which ever one you don't use.
            Plug the last 7 of your VIN into realoem.com and see what it shows for the flywheel. I think you'll find that it SHOULD have an twin mass flywheel. But, unless you know that the clutch and flywheel are original, parts could have been changed on a previous clutch job.
            Until you have the car apart you won't know for certain what you have. And a further complication will be the condition of the flywheel. A twin mass flywheel can't be surfaced and usually needs to be replaced when it is time for a new clutch. A single mass flyheel can be resurfaced.
