Help! Valves Ticking and i cant figure out why!
  • xikyle
    • May 2011
    • 526
    my 1987 325is is ticking like mad. The engine almost sounds like a turbo diesel.
    I've taken the car to the shop and they dismantled the head and used a gasket kit for the cleaning and inspection. they then adjusted my valves and the ticking still hasnt gone away (though it has lessened).
    what could this be?!
    Originally posted by ApexGoblin
    well make sure your priorities are straight... e30 first :up:
  • shiboujin
    • Feb 2006
    • 2791
    It's an m20. It fucking does that.
    • slammin.e28
      שמע ישראל
      • 12054
      Good gawd! Has no one heard of a search?
      • devon.818
        • Feb 2011
        • 2937
        every m20 i've heard ticks. i find it soothing
        • blefevre
          • Dec 2008
          • 4287
          This again? The car ticks, it's not a fancy new engine.
          - E30, DSM, Golf R, Mazda 3 Skyactiv
          • LJ851
            • 7918
            Do some math and readjust your valve clearances at the cam. Its possible the tips of your valves are concave along with your eccentrics giving a false reading from the feeler gauges.
            Lorin
            The M30 is God's engine.
            • xikyle
              • May 2011
              • 526
              thank you LJ851, ill look into this when i replace the valve cover with a shiny refurbished black powder coated 1. :-)
              • colorado_cabrio
                • Sep 2009
                • 891
                Step 1 adjust valve timing.
                step 2 accept that m20 all tick
                Step 3 noob it up
                • LJ851
                  • 7918
                  Step 3 noob it up
                  How do you recommend OP adjusts his valve timing?
                  Lorin
                  • Cabriolet
                    • 9620
                    the Bently manual is something you need to own for this job. ALWAYS do the valve adjustment when the engine is very cold.
                    Much wow
                    I hate 4 doors
                    • crusheroz
                      • May 2011
                      • 6
                      Bump on the M20, accept it..... been there, done that.. they just tick...
                      • xikyle
                        • May 2011
                        • 526
                        I have a bentley manual. ill check for the concave, then if thats all clear, learn to love the ticking.
                        • Bimmerista
                          • Nov 2005
                          • 5425
                          Hahaha! Noobs crack me up.
                          • Rampelsauce
                            • 90
                            The E30 sewing machine. Gotta love it.
                            Join WIBimmers if you live in Wisconsin, dude.www.wibimmers.com
                            • Wh33lhop
                              • 11705
                              It's because you only have 12 valves.
                              paint sucks
