Im having a problem finding this relay. Mitchel program says its in the left corner under driver side under panel. Looked for some time and didn't find it. Anyone have any ideas where it might be?
Ignition relay??? 87 325e
Is it trying to crank? If it is and not doing anything check ur cps. If the starter wont even try check it wiring at the starter and distribution block. If u can hear the solinoid for the starter click but ur starter just stays on till u disconnect the negative battery cable get a new starter. Do ur power windows work?
