Experienced Help Needed
  • Republic
    • Oct 2007
    • 96
    Car won't start
    Deets: 91 318i shell with M20, Mark D chip with upgraded AFM, injectors, and fuel pump. Replaced starter with known working starter. Car will only start by push starting. Problem started 2 winters ago, but worked fine above 50 degrees. Same problem the following winter, fine in the summer. This winter, the problem reoccured but won't start anymore even though it has been hot as all get out. Not sure what the problem is. With being able to push start, I imagine the only problem could be the starter? Solutions??
  • urbancynic
    • Dec 2008
    • 384
    Double check that you're getting power to the starter. I'd imagine that the starter is most likely toast though. Never hurts to double check though.
    • dashboardmonkey
      FUCK YOUR WAFFLES
      • Jun 2008
      • 6158
      does it turn over when the key is in the "start" position?
      prob just the starter tho...
      -Andy
      • Republic
        • Oct 2007
        • 96
        The starter was just recently rePlaced with a working starter from another car, will turn over but still will not start.
        • matt0300
          • 549
          Check to see if ur ignition is bad. If its good try hitting the starter solinoid with a hammer hard. see if that does anything.
          • Marcos
            • 100
            Whoa, don't hit the solenoid if it's turning over. Check for spark first. Does it try to start? Crank crank, stumble stumble? Or does it just turn?
            Spark, Fuel, Air...
            ... Greased Monkey ...
            • Republic
              • Oct 2007
              • 96
              Spark, Fuel, Air...
              Well, it was crank, crank, stumble stumble. Switched starters now nothing. No crank or anything. windows, radio, dash all work, but no crank now. Starter may be grounding out somewhere. Not sure.
              • matt0300
                • 549
                Check wiring
