What the average cost to have valve seats installed
  • mcgrath
    • May 2004
    • 445
    I'm working on a mild stroker project and have a spare eta cylinder head. I can do most of the work on the head to make it flow like a i head but I don't have the ability to install the larger valves like in the i head.
    I was wanting to know what it might cost me to have all of the seats replaced in the eta head with ones for the i?
  • Jordan
    • 12912
    Get an I head....
    AFAIK the valves are the same size. But even porting the shit out of the eta head it still wont flow as good as a stock i head.
    https://mtechniqueabs.com/
    • Jarvis
      • 2132
      "i" valves are +2mm over "e" valves
      • mcgrath
        • May 2004
        • 445
        Thats is why it wont flow as good as the i head. I'm wanting to use the eta head because the bottom end is also an eta. I don't want to lower the compression or put in custom pistons. I'm still looking for an idea of cost to have seats replaced. I wouldn't need them cut or anthing just installed.
        • mcgrath
          • May 2004
          • 445
          nobody?
          • AdamF 88iS
            • 2051
            Depends on which E valves you have. Pre 12/86 they are 2mm smaller (40/34), but after 12/86 they are the same as I valves (42/36).
            Adam Fogg- '88 M3
            Common sense- It's the new 'gifted'
            • mcgrath
              • May 2004
              • 445
              The head is dated 86 I never measured them. I will go check it out!
              • mcgrath
                • May 2004
                • 445
                well looks like its pre 12/86 they measure 40/34 :(
