Tps.
  • ashton
    • Jan 2011
    • 240
    Tps.
    How do you know if your tps is bad? I unplugged mine and nothing changed. Does that mean its bad?
  • PNWDan
    • Feb 2011
    • 1326
    TPS controls the ICV so if your getting an irratic idle 1500 and up I would say its bad. There is a way to test it if you do a search. If you perform a "stomp test" and get no resluts it would mean its not working as well.
    1987 Alpinweiß 325is
    Like the PNW E30 Local Crew Facebook page
    • matt0300
      • 549
      I could send u a working one for trouble shooting for the price of shipping.
      • ashton
        • Jan 2011
        • 240
        How much will you sell it for?
        • matt0300
          • 549
          If a stomp test works wouldn't it pop up 1222? And that could be like ten diffrent stuff.
          • matt0300
            • 549
            Its Urs if u just pay for shipping.
            • ashton
              • Jan 2011
              • 240
              How much is shipping? Lol
              • ashton
                • Jan 2011
                • 240
                My car cuts out when it starts to warm up and it loses throttle. And I turn it off and then like 5 min later it'll do it again.
                • matt0300
                  • 549
                  Idk like 10 or 15 and that could be a bad temp sensor or o2
                  • billybobjoseph
                    • 213
                    Open up the connector under the intake manifold, the big black round one with 7 pins in it. If they are dirty or corroded your brain will think your coolant is cooler than it really is.
                    • ashton
                      • Jan 2011
                      • 240
                      Replaced the o2 and coolant sensor. And it'll be to cleveland tn.
                      • AT-JeffT
                        • 145
                        You test the TPS by checking for continuity between one of the outer and the center contacts.
                        One should have continuity at idle and the other at WOT.
                        • matt0300
                          • 549
                          Still like 10 15 is my guess for 2 day shipping. Is it running rich and could be vac leak
                          • ashton
                            • Jan 2011
                            • 240
                            Can't find what you are talkin about?
                            • matt0300
                              • 549
                              Its the connector for the injecters. It connects right by the coolant hoses under the intake manifold should be on that metal piece bolted to it.
